I have a 1996 225 loop with a 21pitch prop on my v-20 and I average 2 miles per gallon. I typically cruise between 3000-3500 and rarely run wot since this the 225 is more power than the boat needs or was designed for. I will say that it is a dependable good running engine.
Thanks for the info Ferm. I'm not sure if I have been using nautical miles or statute, that was a good point. I had been running a worn out 19p and my cruising rpms were 3500-4000. The reason that I went to the 21p was to lower my cruising rpms thinking that would increse my mpg's. I will start checking my mileage again and compare.
