any idea what this merc engine weighs?
bsteckel
anyone know the weight on a 1994 merc offshore 25" 225 hp? i know that it is a 3.0 l and carbed.
other than that .. i have no more info.
thanks
any idea where i can for an exact weight? nada lists the motors as weighing 395 lbs. want to make sure. nada seems kinda light.
thanks
Brad
398 is about right for a 2.5 L 20 inch, the 25 inch weighs a bit more, and the 3.0 l weighs abit more than the 2.5, I'll see if I have any of the older sales brochures in the ofice tomorow that might have an acacurate weight
Brad - don't go to a 3.0L. They're good motors, but they drink fuel ... like 15-16 gph at 4000 rpm cruise.
Not to mention how much oil they use if still oil injected. We had a PRO-LINE 231 with a 225 MERC on it. The engine wasn't really horrible on fuel as the boat got ok milage(roughly 1.5 KMPG), but the oil it used was UNREAL! It had a 125 gallon fuel tank and a 3 gallon oil tank, you would run out of oil long before fuel.
stumbled on this 3.0 very close to my house .. real clean freshwater .. looks like new. even comes with hydraulic steering.
one cylinder is low on compression .. owner wants nothing to do with it, just bought a new motor. maybe i could get away with fixing one hole if the others are good.
price is right ...
not really what i want .. but if i could fix it reasonable, i could use the extra money for gas:)
they burn that much??? i tried to do a search, but did not come up with much info.
i love the 175 that BS has .. but those chrome bores scare me .. read about chrome peeling and much $$ to steel sleeve or get re chromed.
i would like something i could rebuild more cost effectively if something bad happens.
but it is not out of the picture yet.
Them 3.0's are best suited for 23+ boats weighing in at 5K+ in weight as well. For a stocker I wouldn't let the chrome bores scare ya. It's made it almost 20 years without issue, I would expect it to stay the same for a few more to come. Aviation uses ALOT of chrome bore cylinders without issues.
