Finally fixed, RPM's still low
Joker2
Finally fixed motor, when the mechanic gave me a newer control box he spliced my harness and did a crappy job. The bl/ yw kill circuit wire was exposed int three spots and so was the yw / rd power wire. redid the whole thing " the right way " she runs better than ever real smooth, no shaking. I am still only getting 4-4200 RPM's though. Speed is 29-31 MPH at 4000. Prop is 15-1/2 X 15 Alum. she jumps onto plane. I can get a hold of a SS 14 X 19. My friend has this on his 21' Hydra Sports ( heavier than mine )with an 89' 200HP Evinrude on a gil bracket, he gets 6,000 RPM's sometimes more, and his boat is FAST ! not sure exactly the speed but it has to be around 45. Do you think this will make up the difference? Will it be a dog out of the hole? Also the mechanic told me when I bought the motor that he put on a lower unit that was a newer year than the 94' motor, could the gearing be different in the lower unit ?
good to hear you found the problem, Thats why I suggested separating the harness from the engine. have you checked your tach against another one?
No, I'm not sure the best way to check. I have asked what the normal idle RPM for my motor is and Was told by users on this forum it should be around 700-900 which is what I have. Could my tach still be bad? do my speed and RPM numbers sound like they are on track ( 30 MPH @ 4000 )?
went out today, ran good, I was alone with no gear and 20 Gall. fuel, got it up to 4300 RPM's 32 MPH going with the tide, light wind, trimmed up all the way.
