Fuel Hatch Rebuild Starts, Billfish16
billfish16
After reading on this Site how to rebuild a Fuel Hatch Cover I decided to give it a try even though I never worked with Epoxy and Fiberglass. I started off buying the Lowe's Poly Resin but had second thougts about the quality and returned it. The last thing I wanted to do was do this twice. I bought the West System from West Marine even though it is much more expensive. I was lucky enough to have a Sales Person who actually worked with Fiberglass and Epoxy Resin. He suggested I go with the Slow Hardener even though it was about twice the price of the Fast Hardener. I later found out it was worth the added expense and more.
I flipped the Hatch over onto two saw horses. I started with a Circular Saw to cut the underside fiberglass skin. I dropped the blade just enough to go through the bottom skin. I went around the perimiter of the raised area that covers the plywood.
I was able to pull some of the fiberglass skin up by hand but I used a large chisel to speed the job up.
All of the skin is removed showing the little plywood squares that every who owns a V20 just loves. These were waterlogged and most came up easily with the chisel.
I used a grinder that I bought for $30 to knock down the fiberglass(see below) that was left around the perimeter of the plywood squares and the little bit of plywood that did not come up with the chisel or scraper
I cut a 3/4 piece of Exterior Grade Plywood to replace the damaged plywood that I removed. I then Epoxied the Plywood to the underside of the hatch. Because of someone else's misfortune on this Site I learned to use lots of Epoxy because the Plywood seems to absorb it. I also spent another $10 for a filler additive for the Epoxy. Since I was using the the Slow hardener I coated the underside of the Plywood first and let it soak in for 20 minutes and then added some more to the wood before coating the hatch and sticking them together. I also poured extra Epoxy on the Hatch in several places. I used lots of weight(5 gal buckets filled with water) on the plywood to keep the two pieces sandwiched tight while it cured overnight.
Now that the plywood is cured to the underside of the hatch I am ready to lay the fiberglass over the back of the plywood.
More to follow............
I know you guys like pics but I am over an hour away from the boat plus I have a job, two kids and a wife. More importanltly I still need to go out and fish...on my friends Bayliner Trophy, I know, I know a Bayliner.....but it gets us over the fish. The Hatch project is a little farther along than I have described above but I do not have pics to go along. I will not be foolish enough on this Site to go any further without PICS.
Seriously I could not have tackled this project without the people on this Site and their willingness to share their expertise as well as their misfortunes.
I have another project regarding my Transom which "Swells a half an inch" that I am just in the preliminary stages. I will post an updated picture or two on that subject today.
Bill
Very professional job there Billfish and nice documentury too!!
reguarding your swelling transom- might I suggest some butt paste and please no pics... This is a family site!! ;D ;D
Parker Resin
Hammer
Do you know if tha parker resin that Skools gets is available to the general public? I need some of that or West system I guess. I've been so busy I have not been able to work on my boat. So I finally have some time and I'm on it hard and heavy. Thanks
I know everyonr is gonna howl when I say this, but those squares are supposed to be there. I didn't use them when I fixed mine, and I had a little problem putting the hatch back on. I have it on "good authority" that wellcraft used squares for a reason.
Just my 2 cents worth, feel free tu use what ever you want.
nice job by the way Billfish, thanks for the pix!
Whatnot, not sure whats available on what SKOOL use's. I still stand behind West System. Strong as hell. Plus for someone like me, its idiot proof. They have special pumps for the resin and hardner so you cant screw up the mix. ;)
