Hatch liners?
shicks007
Have any of you ever tried to use hatch liners in your molded in deck boxes? I'm considering this as an alternative to grinding and filling and sanding and filling and sanding and filling and sanding (get my point?). My thought would be to epoxy them into place and bore the hole for the drain, not necessarily in that order. Any thoughts or ideas would be great.
Thanks,
Scott
Something like this, I'm not sure of the size (I'm at work)
http://www.basspro.com/servlet/cata...rch&cm_pla=I-search (Froogle)&cm_ite=DDI link
Yeah man I have definitely thought of that and I am considering it. If I can find the right fit I will most likely do it, just not there yet.Try it and lemme know. ;D
Also check out fpmarine.com, under plastics (scroll down to the picture). They have a wide assortment of insert boxes.
Well, Iv'e searched high and low and every liner manufature that I've found does'nt make the size I need. It looks like it needs to be 17X30X9-3/4.
