Electric over hydraulic describes the Bennett Tabs. The switch on the dash operates the electric motor which turns a pump that sends hydraulic fluid to the hydraulic cylinder mounted at the transom.
Lenco's are pure electro mechanical. I have never seen any hydraulic Lenco's. They have a nylon threaded bolt and nut arrangement inside that gives the electric motor a mechanical advantage.
For $200, you can't buy either one new. It is your call. Either will work, both are well supported by the manufacturer. Bennett is prolly the best but harder to install due to the pump placement.
