Hey just got my first v20 78 has cracked block picked up 350 getting ready pull 305 this thanksgiving weekend any tips to look for or be aware of any advice would be great
Mercruiser I assume? where are you getting the replacement engine from? Make sure to put new manifolds and risers on when you swap it out. Don't cheap out and use car stuff
Alpha one drives? You'll need to swap everything...motor, transom plate and drive. Yes, you can swap some of the components to make it work, but youre better off swapping it all. Take the time to rebuild the transom plate while you have it on a bench. Bellows, water tube, shift cable etc..
front motor mounts should be in the same location, or close enough. Rear mounts differ between the older engine/transom plate and the newer engine/transom plate. The exhaust y pipe stays with the transom plate. Keep everything together as a package
