My friend with an issue.
My friend ( yeah I have one) has a 19 foot bay liner with a 2018. 150. 4 stroke mercury. He says his top speed is only about 25 to under 30 mph. He doesn’t know the prop size . He is new to boating and he also says it cavitates some times. I know what I told him but I would l8ke to know what you guys think? I don’t know to much about 4 strokes since I still have my 2 stroke 150 mercury he also said his rpm’s tops out about 4000 rpm’s. Thanks for any reply’s
4k rpms is around cruise speed on 4 stroke. Wrong prop as you suggested, or, if it had been running faster, it could be a number of things including dirty bottom of hull, or possibly the shift linkage needs proper adjustment? Basically need more info - did it just start doing this behavior, OR has it never run more than 25 - 30? He should be turning well over 5000 rpm, on up closer to 6k in my opinion.
Hi Blue. He just got the boat and doesn’t know to much about boating or the engine. I told him to see what prop size he is turning. I told him on my 150 2 stroke I’m turning a 15 x 17 inch prop and it’s a perfect marriage. Bu5 I don’t know if 4 strokes are the same. But is sounds like something is not right
Hi spare. Yes it has bottom paint and I ask him it could be covered with barnacles but he told,e it’s clean. I told him to check the prop size. I hav3 a question ? A 2 stroke or a 4 stroke Same hp would it be the same speed? At W.O.T. ? I don’t know ?
gear ratios varym quick google search says 2/1 or 2.4 to 1. Your old school 150 would have been 1.87 or 2.00. Its goinf to take a little higher pitch than your old engine. merc has a prop speed calculator online to figure it out
Sounds like he may also have the engine set too high on the transom. Easy to check, just hold a yardstick flat on the bottom of the boat on the keel and see if the cavitation plate on the engine is above the yardstick.
Good 19’ hull with properly working 150 should run about 45 mph +\~.
Max rpm about 5,200.
Eliminate each the others listed on at a time plus check outboards compression.
I think his motor is good but I would bet his prop is not. You know what gets me mad. People ask you for advice and when you tell them they don’t do anything. So why ask? What I should have said was gee that don’t sound right. I don’t know. But we / us try to help when it comes to boats and motors. If I have an issue with my engine. This is the first place I go. The only problem is when Spareparts gives me advice it’s above my knowledge of engines. Sometimes. But sometimes I do understand. But you guys are always there to help.
Hey spare. Move to New Jersey.
