Brettnrs423
Hello everyone,
For those of you who might remember me, I was in the process of changing out my fuel tank several months ago and posted here. I am starting to think that I made a poor choice on buying this boat (I have a 1986 V20) because I have had nothing but problems since I got it. As an update I pulled the tank last season and was able to use the boat for the remainder of the season with a temporary fuel tank until the original yamaha 150 seized from an oil injection failure. I am at the point where I have pulled and sold what was left of the outboard and need to decide between restoring the Wellcraft or buying a new boat. Fortunately I am willing to tackle most work myself as I am very mechanically capable but have never really done fiberglass or paint work before. Where the boat sits it looks like there is solid material in the transom, however it is very brittle and flakey. I am thinking that I should probably rebuild the transom if I am going to keep the boat. In addition, I noticed a cracked chine on the bottom of the boat from contact with the trailer. I have enclosed a few pictures of the damage but would like some advice on the best way to fix it. Unfortunately, its in a spot where I will not be able to access it from the top unless I cut up the cuddy. If I am going to restore the boat I am going to do it right: Fiberglass repair, new tank (which I already have), transom replacement, new outboard, and new paint/gelcoat. I was hoping to get some advice regarding all these repairs and about how much I could expect to spend. As far as an outboard, I will be going with an ETEC 150 if I decide to keep the boat, which I have already priced out at a local dealer. So what does everyone think? Am I in over my head? Is it worth restoring the wellcraft or should I just try and find a nicer boat in the 20-25k range? Thanks in advance.
-Brett
-Brett
