not sure of you motor, but run your motor on premix and disconnect the the oil injection line and measure the amount coming out. on a merc 150 2.0 its
@1500 rpm with oil pump link arm attached = 6.8 cc +/- 10% in 3 minutes
@1500 rpm wiht oil pump link arm disconnected = 17 cc +/- 10% in 3 minutes
if you've got a jonrude, i'm sure they have similar specs and one of the omc guru's will chime it later.
