sweetseason
have been fighting and running out of money for the past 3 years with an overheating problem. Several mechanics - most of which I will never talk to again, cant seem to figure it out. It is an I/O 470 merc with the heat exchanger. Both water pumps have been replaced. (the one in the outdrive and the one on the motor)
Please help
The engine will run all day out of the water and work fine (hooked up to a hose)
The engine will in the water all day at slow speeds
The engine will overheat if run for about 20 min at plane speeds
The engine coolent is expelled to the reservoir at this time until it is all expelled and overflows onto the engine block.
The thermostat has been replaced and I can watch the temperature gauge and see when it kicks in at slower speeds.
At high speeds I watch it go up and keep going up untill it overheats.
What is going on?
I plan to dissasemble the entire cooling system myself in the spring but I dont know what to look for considering everything That pumps water or coolent has been replaced.
One mechanic suggested I find someone to hook it up to a dynometer? Everytime I take this boat in it is a $400 dollar bill so I have aready spent more than this boat is worth. Bought the SELOC repair manual for myself for christmas but I dont know what I am looking for. Anyone have an answer for me so I can get out at more than 15mph? 1979v20 470 merc
Thank you
Paul
Please help
What is going on?
Thank you
Paul
