racor filters on Ebay
i guess since SeaPro became Brunswick owned, they want to use Mercury filters, ssome one probably got a steal on those filters
Thats a awesome deal!! he has it as a $ 20.99 buy it now with $5 shipping.
Did you get yours yet?? What size are the lines?? He says he knows nothing about them as far as flow and stuff?? I need it for a 225 hp
Thanks for the link!:clap:
Found some info on another site but no definitive answers.....I'll let you know when I get it.
http://www.ohiogamefishing.com/community/showthread.php?t=86398
http://forums.iboats.com/showthread.php?t=235159&highlight=racor+ebay
I did find a site selling something that seems comparable...
http://www.starboardsupply.com/product_info.php/products_id/3012941
If you order one, get one for me too.:party:
Says they are for inboards, But I am using my I/O on my outboard with no problems.
Rated for 30 GPH
Racor 120RRAC01 Gasoline Spin-On Series Fuel Filter/Water Separators Gallons per hour- 30
Port size- 1/4-18
Bowl- See-Thru
Cost: $55.92
Racor 120RRAC01 Gasoline Spin-On Series Fuel Filter/Water Separators Replacement Element Number S3240
Racor S3240 Gasoline Spin-On Fuel Filter Elements Application- Inboard
Fuel Type- Gasoline
Fits Model Numbers-120R-RAC01
Cost: $13.97
Rated for 30 GPH
Port size- 1/4-18
Bowl- See-Thru
Cost: $55.92
Fuel Type- Gasoline
Cost: $13.97
MJ, I have been digging around also and the ones for inboards appear to end in 02 ie 12R-RAC-02 vs 120R-RAC-01.....the difference appears to be only the clear bowl on 01 is not approved for inboards by the CG...02 has a metal bowl. Here is a link to a tech manual.
http://www.a-filter.se/files/racor_products.pdf
My question is about the maximum gph.....the manual says the 120R is for "smaller" gasoline engines up to 30 gph.
There is also a guy selling a couple of bigger ones on Ebay if anyone is interested....
http://cgi.ebay.com/ebaymotors/RACO...015QQitemZ250229942555QQrdZ1QQsspagenameZWDVW
those are a bit small for big v6 OB. I just use the standard Mercury/Sierra/GLM/Yamaha/AquaPower type filter head, then use the Racor element on it. Those filter heads will handle just aboout anything you hook to it.Right now the Yamaha factory filter is specced at 10 microns, and its atleast 10" long
if teh restriction is of concern, plumb in a vacum guage(Racor makes them but they are $95) and see how much they pull. Most of the engine manufactures recomend no more than 2"HG, but most of them end up around 5"HG
If you're burning more than 30 gph with your single outboard motor, chances are you're not buying your filters from some guy on ebay.
I got mine a couple days ago.....it is a bit smaller than I thought. I was thinking of leaving my current filter and adding this after it as a secondary filter. The current one is a standard screw on type filter.....will this be OK?
I thought the same thing smaller then I thought. There is no problem leaving two inline.
I might do the same to see if it can handle the fuel consumption?? Fir this it has to be after the other filter. If all works out well I will lose the other and stay with the new one.
