Raw Water Wash down set ups
Dschaffer
Hey all,
I’m thinking about installing a raw water wash down kit and am looking for recommendations on brands and installation locations. I might also install an additional bilge pump so if you have a recommendation for that as well, please share. Thanks
on my Grady I have a Shurflo BlasterII 3.5 gpm, bronze thru hull and a ball valve in the stern bilge area. I have a separate livewell pump bronze thruhull & valve.
We do a lot of fishing...tuna fishing...and it is a neccessity...but some of the guys go crazy spraying salt water. If you are in salt and you don't have a blood & bait issue, it might not be worth it.
I never got around to putting one on my V20 but I thought about it alot. We just dipped the brush in the ocean and scrubbed....sometimes a 5 gal bucket dumped on deck...we got by.
A washdown pump is high pressure and not on all the time. It does not double as a livewell pump which is low pressure and can run constantly.
If you plan on having a livewell, you can share the thru hull with the washdown.
Oh, on my V20 cuddy I put a second bilge pump forward. I had cut out the floor of the fishbox to remove junk that was blocking the pvc tube for bilge water.
I ran the hose back inside the gunnel to the starboard side under where the other bilge pump outlet was.
Its good to have a fwd bilge pump if you dock all season because that is where the water collects first. And its good to clean out the junk blocking the drain pipe!!!!
Thanks. I’m in fresh water only. I currently just splash a bucket on the deck so a sprayer will be a nice upgrade. Instead of a through hull set up I wonder if it would work for me to run a piece of 1” pvc down the transom to below the water line. Then just elbow through somewhere in the engine compartment to the pump and then run some pipe from pump to where ever I decide to put the sprayer/hose.
I currently trailer the boat but am considering renting a slip this year so a second pump is going to be a must. Thanks
I don't think a washdown pump will prime if it has to pull water up an empty 1" pvc tube. Download the op manual before you buy....
I bet you’re right. I see they have portable versions where you can put the hose/tube overboard while using. Maybe I just need to make one of those into a more permanent set up. I actually like that idea quite a bit.
Thanks
Had 1" thru hull scoop strainer on my grady feeding both washdown and livewell pump (water puppy impeller vs diaphragm). Water puppys dont last in a wet environment though good for 1-12 yrs the diaphragm pump would be the backup when the other failed, 5 impeller pumps in 10 yrs and 1 diaphragm in 10 and still going strong
never had an issue with drawing water from either at about a 2 1/2 to 3 ft
Just added a 3/4 to the V20 last week, planning one pump for both
Nice job. More then I want to do. Diaphragm is definitely the way to go. The pump I’m looking at has a 6’ vertical draw so my pipe out the back idea should be good to go. Where are you putting the hose and sprayer on the V20?
Port side of the well there is an old electric plug thinking there with a Y for the livewell and washdown
