Replacement Side Fishing Rod Holders / Gunnel Rod Holder
AJC
This is my first post. I am looking to replace the side fishing rod holders on my 1987 V20. Has anyone else replaced theirs. Mine are cracked, and I want to repalce the teak trim with marine plywood type trim.
One of the recommended places for replacement boxes is
http://www.ssicustomplastics.com/
I dont believe they make one thats and exact size so you would have to open your holes up a little bit to make them fit. Definitely not cheap but the look nice.
There is a guy here in NJ that has 2 from his 1986 V that I can put you in touch with. They were in decent shape, the only parts missing were some flange areas that are covered by the trim anyway. Mine were the same faded yellow color as his which I painted and they look brand new. You can see a pic under the posting http://www.wellcraftv20.com/community/showthread.php?t=10985&page=2
Welcome to the site by the way!!
Thanks RWilson2526. I would appreciate it if you could put me in touch with the guy with the rod holders. Where is he located?
He is in Morris Plains, NJ. off of 287 just south or route 80
His name is Tom
I recomend that you try to fix them. If you remove them, sand out the cracks, tape wax paper on the sides, fill holes and cracks with glass, let dry, sand and paint, you are left with beautiful original gunnel holders. Save the teak too. A little care and nothing will look better. here is a pick of the holders I redid. Looked impossible to fix - totally cracked- peices missing- 30$ worth of supplies and I was glad I didnt cut my boat up to put some in that dont look like they came with the boat
rod boxs
My v didn’t come with any just holes where they used to be an owner before me must have tossed them. Mine are the type like the ones in the pictures with the angle in the front and rear. i took some measurements and squared off the angles and i would need a box with an inside dimension of 72 to 73" none of the box makers i have found have a box with this dimension. i have found 68" and then it goes to 88" 88 is way to be for any of the polls i have. Any suggestions? Thanks ~JOHN~
yea you should have never cut them till you had the new ones!!
But now that you have i guess i would get what fits the closest and add starboard to the ends to fill the void.
rod holder boxes
Hello,
i havent cut them yet, i just think the odds of finding orginals are slim to none my cutouts still have the angles and are the factory cuts im sure, i will try to post some pics tonight. Thanks ~JOHN~
Or
Check fpamrine.com and you can get creative and install some storage boxes like this to fill in the open space ..
