Rewiring a 90 center console
Broad question. You need to try and match switches/fuses to your needs. As for a harness, that is going to be all up to you. No replacements that I am aware of. There are a number of fuse panels that are setup for bilge pumps, lights, etc. How many circuits do you need/want?
I have had my best luck with a panel similar to this with the rubber coated toggle that also covers the hole the wire goes through. I used to go through a rocker-style panel every year for about 4 years. I've had this style for 3 years now.
Also, use only marine grade tinned wire and make sure you use heat shrink everything you can. If saltwater/spray can get inside the butt connector, it can eat through the wire within a week.
