Shift & Throttle cables
bigirishk
Hey all,
I have a sticky transmission cable and was wondering if anyone knows off hand what length replacement I should buy. I have an '83 cuddy and I hate to take it out just to measure before I buy since it actually works it's just slow reacting at times. How difficult is it to lube the cable? They look like Morse cables and are going to a Johnson motor.
Thanks,
K
Irish - If they're morse cables there will be a number stamped on the side. This number will tell you how long the cables are . . . the last two digits equals the length in feet.
check out page 5.
http://www.teleflexmorse.com/scripts/PDF/Blue/ControlTech(v3).pdf
You have to measure from the box to the corner and then to center of motor, then add 2 feet for a loop so the cable move freely. Round off to the nearest foot and there you go! ;D
That was my thought when you were telling me before But thought you should measure first!!
But if you got 15+ then you should be going 17'
thanks .way back ,iforgot my password an had to start over with a new name. well same name just spelled a little different.id like to get my pictors back on . they disapered back when the site was changed.can you help b.s.
