Spare & Therm
Can I repair / replace the seals and O rings on my hyd lift cyls for my volvo 290 duo prop outdrive without taking / disconnecting the cyls from the transom? If I take the top portion of the outdrive off I can lift the outdrive out of the way to work. It's almost impossible to get to the
bolt(s) that holds the cyl(s) to the transom.
i'm working on an answer, I have to do a little research, i don't think I've ever had a pair apart. Did you ever call my friend in Raleigh about his Volvo stuff?
