Sudden RPM Loss?
My 2000 Johnson 150 carbed model developed a sudden loss of rpm this weekend. I was running the motor at full throttle when it dropped from 5400 down to 4500. When I floor the motor it sounds like for a split second that it may achieve full rpm's but never exceeds 4500. The motor is also stalling occasionally at idle. It had been stalling at idle before the sudden loss of rpm's. I have also noticed that the throtle advance plate under the flywheel seems to be sticky. I plan on checking compression and spark and I have elimintated a water in the fuel tank problem, by running off a portabe tank and also changing the fuel water seperator. Any suggestions?
sounds like 1 of 4 things i seen cause this
1: Replace all the plugs may be one bad plug
2: Check for fire on all cylinders could be bad coil pack
3: Check that Magnets are still in place under the flywheel should be able to without removing it
4: Test Compression let us know all ya find
Good Luck Hope it's not an MJ type motor issue ???
I won't know anything till this weekend when I get back down to the boat. The mechanic I was planning to use said that I shouldnt expect to get my boat back for 8-10 weeks because he is backed up. 2 1/2 months :o I thought that was crazy. So I just bought a manual off Ebay, full price but its a factory manual and I needed it. Hopefully I will have it by this weekend so I can get to diagnosing. I hope its not an MJ like problem, thats my worst fear.
I had a 120 doing the same thing and it was just a bad plug somewhere they all showed fire. I went threw that motor over and over finally put a new set of plugs in the motor out of a known good running motor and that fixed the problem. I'd try a new set of plugs first off. Actually do a compression test if all good go to the plugs. the set i threw away from the 120 were new only had the boat out once and it did that so new is not always good.
there is a possibility you could have sheared a key way in the lower unit......that is a common reason for loss of rpm when you have it at full throtle
Angler, I can see it being something with the lower unit because it lost rpm when I was going trough a choppy wake. I was racing my brothers boat and should have slowed down but I didnt and when I hit the wake is when I lost power. How would I check for the stripped keyway?
fuel pump also?? after installing plugs go in water if still the same try having someone pump the ball, and see if it gets full RPM's?
I cleaned the fuel filter, changed the water seperator, drained all six carbs and also messed with something called the vapor seperator.  I dumped her in and hit the magical 5500 rpm's I longed to see.  Thanks for the suggestions boys.
Mulv. any pics. of te water seperator ??
Wondering if I had the same problem. See a water seperator that was attached to the fuel filter, but my V doesnt have one attached to the fuel filter. Costly at 85.00. I have new plugs and fuel lines, can only try and replace teh fuel filter and see what she does.
If by chance you can post any pictures of the parts you changed out would be great.
Mike, Sorry still no pics. The fuel seperator you are talking about is probably a Racor Water Seperator with a clear bowl. You can buy a Tempo brand water seperator kit for under $30. The replacement filters are much cheaper about $10 each. Whatever filter you buy make sure it is a filter capable of filtering 10 micron that is the prefferred filter for the new ethanol fuels. You may have water in your fuel, unless you feel like pumping out whatever fuel you have in there and trying to dispose of all that gas, I would just install a fuel water seperator and change the filter often until you have the problem under control. Your motor probably has a screen or filter of some type on the fuel pump, you shoud take it out and clean it. My filter had what appeared to be little brown particles. I heard that the ethanol in the gas has a tendency to break loose some crud in the fuel system, so keep a close eye on those filters.
