keepitgreen05
I recently purchased a 1987 v20 and i want to refinish the teak wood on it i have no idea when the last time it was oiled do you thinks it will be better to replace it or sand it and oil it again.
Two other suggestions: remove all of the wood from the boat before doing any refinishing. It takes a little more time at the outset, but the job will go much, much faster and you'll get much better results.
If the teak was previously finished with any hard coating or finish other than oil, first use Zip Strip to take it off. It works very quickly. You can sand immediately thereafter.
