fishingwithblue
Po
pped the top!
Deck removed and see a tank that looks bigger than the hole. Top is in good condition. Port rear corner looks dingy and moist with gas. Tank stearn foam is saturated with water and gas. Rest of the foam looks dry. Fill hose is near dry rotted. Ground wire near fuel pickup hose broke off. New tank coming Fri/Sat. Fuel pick up valve looks like hell.
Took the hatch off and began to pull old fiberglass. The wood is saturated with water but the fiberglass itself is in excellent condition. Seems like a waste but here we go.
I'm working on the hatch while the gas siphons but have to replace anti siphon nipple to get flow. Also remove 2 pumps from the bilge area that were burned up in attempt to replace and rewire entire boat......the V20 marathon continues......advise welcome!
