Trailer brake help needed!!
3 Squids
Hi guys. I have a trailer with strictly electric brakes. It's a brand new trailer and the brakes seem to be fine on the trailer end. If I pull the emergency release cable they lock up. If I use a 12v source and touch the trailer cable in the 2 correct spots the brakes lock up.
Here's where I am lost. I have a 02 F-250 with the factory tow harness. Factory brake controller harness and a new Prodigy controller (I bought this as I believed the Reese one I had was the issue). When the trailer is plugged to the truck the brakes do not function. When it's hooked to the truck and I pull the safety cable they will not lock. With the safety pulled and then I unplug the 7-pin connector the brakes will lock. If I plug the 7-pin back up the brakes stayed locked.
On the truck at the plug when the box is turned all the way up and brake pedal pushed I get a 11.5v reading using the trailer ground pin and trailer brake pin. Voltage drops as it should when I lower the setting on the controller.
I've checked and made sure everything is grounded well. I made a jumper wire from the truck plug ground to ground to the pigtail and used another jumper in the trailer brake slot from the trailer. Now here's where I'm stumped and maybe it's something common. With the control box turned all the way up and the brake pedal pressed, the trailer brake terminal and both left and right brake light terminals have 11.7volts with the multimeter. If I touch the brake jumper wire to the trailer brake terminal on the truck nothing happens. If I touch it to either of the brake light terminals the brakes engage. All 3 have + voltage. What am I missing?
Have you pulled the drums and looked at the magnets? Apply the brakes and see if the magnet will hold a wrench. Keep in mind, the wheels need to be rolling for the brakes to apply. Has the trailer been put in salt water? We fix trailer brakes with a torch around here,
What am I missing?
Squidder, please don't take offense at this reply. I know it sounds flippant and smart a$$ed, but really it's not. As I see it, in answer to your question above about what are you missing... The answer is simple. ....Surge brakes.
It's the old KISS principal again. Keep It Simple Silly. Surge brakes are mechanical/hydraulic. No magnets to go bad, no wires to corrode, no tearing your hair out testing 7 different electrical connections, etc, etc. Just straight forward physics As long as you keep your brakes clean (Disk or Drum) and you check your brake lines and fluid about once a year they will reliably stop your trailer every time. Think about it. There's a reason that brakes on cars are hydraulic and not electric. They simply work. And really, after all is said and done, isn't that what you want?
I should of noted this is not a boat trailer. It's my enclosed 14' work trailer. Like I said it's brand new. And the magnets seem fine. Like I said if I just use jumpers from a battery they'll lock the wheels right up (I jacked one side up). It definitely seems on the truck side. Just so confusing that if I apply the 12v (or whatever the brake box is putting out) to the brakes nothing happens but the voltage from the brake light pin activates them. My buddy is supposed to come by this weekend with his truck with a box in it and try it out. I guess that'll really tell me if it's the truck or trailer.
Squids, not real familar with electric brakes, so all this is a guess. I'd verify that the 7 pin connector is matching the trailer. Do all the lights work properly? That would eliminate 4 wires (right, left, running,& ground). That would leave 3. (Brake, 12 vt constant and reverse). If everything is right on the trailer, verify the truck. We had a new flatbed trailer at work that would tap the brake everytime you turned the right blinker on.
If all that checks out fine, check voltage while under a load. Sometimes those 11.5 's will drop when put to work. Also might try checking without the trailer hooked to truck, this will eliminate any stray grounding through the coupler, which can confuse the issue.
My tahoe only has the 7 pin connector and i had a bad adapter, 7 to 4, that drove me crazy.
Good luck
Sounds like u have a truck wiring problem. If its a new trailer go back to where u bought it and see if they will let u hook up to another trailer to make sure its not the trailer. If u need any info from the truck side let me know, I have a 99 f350. wiring should be similar.
They should all be standard Squidder. 7 pin plugs are just like 4 pin plugs. Industry standard wiring. And usually any problem can be traced to a poor ground someplace.
Here's a wire layout of what should be going where. Hope it helps.
Grounds are the most overlooked problem. All your power connections are only as good as your worst ground, grounds between controller and truck, trailer and truck, and device and trailer.
agree, there needs to be a wired grnd connection (white wire) from truck chassis to plug and from plug to trailer. Some trailer plugs don't pass the ground thru and rely on the connection of the ball & hitch.
and sometimes you have to run a ground wire all the way to the studs of the lights (or brakes) and not rely on the trailer chassis as a ground.
A common symptom of bad grnd is that your lights appear to work until you turn on your parking lights and then your brake lights don't work. This is because the circuit is using the 0 volts on the parking lights as a return until you put 12v there, then it doesn't work.
Some vehicles have yellow turn signal lights separate from brake lights. They require an electronic adapter because trailers use the same lamp filament for brake and blinker. When these adapters stop working, weird stuff happens.
Found the problem. The blue wire in the factory harness is grounding out somewhere between both ends. According to the FSM it doesn't have any splices in it just a plug at the firewall harness. I cut the blue wire coming out of the control box and connected a long jumper wire to it then ran the jumper wire straight to the trailer and sure enough the brakes work fine. So for a quick fix I ran the jumper along the frame to the back of the receiver plug and all is normal now.
That would make sense since the blue wire is the one that goes to your brakes. Glad you found the problem Squidder. :clap:
