i am buying a 84 V20 I/O without a trailer. i found a trailer (91 venture single axle no brakes rated at 3000lbs. just wondering if this would be sufficient. i know the boat weighs 2,620 empty. any help would be awesome. ???
Use the fact that you'd rather have a tandem trailer as a bargaining chip on the single axle. Tell him you really want a tandem, but you need something quick so you'll give him $500 for the single axle trailer ;D
If he says no, then take him up on the $700 and that way, at least you tried to save money.
BR...is "grease thru a goose" what you had in mind... ;D...
Your boat's gonna RIDE better than any other 20'er compared to other boats...it's heavy, has a deep V and wide bow flair...plenty of room...which motor did you get?...Franco's got a 225 HP I/O that runs like a BANSHEE!!...You are close on that trailer, but if only a short trip to the ramp, shouldn't be a problem, but I would recommend regular maintenance (good tires,Goodyear Marathons if the budget allows, new bearings and seals and grease regularly...)enjoy your boat, learn it and keep us posted, pics if you can... ...
One axle ought to be ok for a short trip. Just make sure you keep the tires / bearings in good shape. And don't forget to tie it down well. Nothing worse than having your boat scattered all over the highway. Anyone ever add an axle to a trailer? That might be a reasonable way to increase the capacity.
just my 2 cents worth - dual axle because a 45 mph tow + 1 nail = a bad day - I have to replace my trailer too - I've decided to bite the bullet and go dual axle w/brakes. I live within 10 miles of at least 10 boat ramps - but I want to tow mine to the keys from time to time.
The first time you feel that soft landing hauling a$$ in an easy rolling swell and that sweet bow flare throws the water out 50 ft. on each side is sure to give you that worm and fuzzy feeling inside.
I have a new loadrite tandam no brakes, and it is great!! Of coarse I pull with a full size truck and the weight of the truck is greater then the boat.
