Not alot different than patching a hole in some sheetrock huh...I'd be usin the screw hole surrounding the larger holes to attach some plywood, a secondary piece of ply cut to the shape of the hole to fill in. Epoxy the plywood to seal. Glass everything over and fair until even and smooth.
Zebra said:Ive got all these holes in the gunnels of this boat was thinkin maybe use thin starboard about 3" wide and run a strip down each side. go around the bimini frame
Us contractors call that a "weather cut"chumbucket said:That would look good too RAP. What you do at the seams is to lay a table saw blade down to the shallowest angle you can get and cut across the width. Then the next piece will have the reverse angle to lay on top of the previous piece. That hides most of the seam line. You would do the same thing for interior and exterior trim on your house for long runs.![]()
