VRO fuel pump needed
Hedge
Do by chance any of your parts hounds have a good VRO V4 fuel pump. I had order a supposedly "almost new" one that has cracks all over the housing and leaks like a sieve. Needles to say I ain't putting that thang on my v.
Man I'm fresh outta those...but somebody'll be along w/one in their pocket...:news:
This statement right here is reason enough to dump it and pre-mix.
I wouldn't want to trust the oiling of my engine to a 25 year old part known for breakdowns.
Sorry for the confusion guys. I do premix. The VRO system was immediately disabled by Skools the second he got his hands on the boat. What I need is the V4 fuel pump. Like the one pictured
Destroyer. The second pic of the pump is exactly what I need. I will call and see if they will ship. Thanks.
looks like a cross flow, pull the plate off the manifold where the hos hooks up and you can mount a pre oil injection fuel pump right in place, you may have to play with the fuel lines to make the bend
Spare:
Here's other pics of the motor, maybe you can determine from these, then put an APB out on the dude in the pics.
You have a looper, so you MUST run the VRO style pump. And all VRO pumps for the V-4, V6, and V8's are the same(just the V8 uses 2). I'd offer you the one i have, but it works for about 5 minutes and hangs up and blocks off all fuel flow. Chased it for over a month before I finally figured out the diaphram was blocking the fuel flow when it hung open.
Hey ferm what about using a merc v6 remote mounted pump. They are way cheaper than the omc pump. I ran a cross flow v6 on my 120 looper with out any issue. But I remember you said something about a cross flow pump not working with a looper . Seems like the Merc would be the way to go
The MERC pump may work as it would be meant for a loopers lower crankcase pressure. I know I tried a regular OMC crossflow pump on my 140 looper, and it worked great until it hit 4000 RPM's, then the pump just quit working. The VRO pumps are designed to work well with virtually no crankcase pressure at all, and is why they work on the loopers.
Guys I'm going out on a limb here, but would an inline fuel pump work? Something like this... Showing 4psi
It should work, just make sure it can supply 4-6 PSI while flowing 20 gallons per hour(a 120 shouldn't burn but about 14 GPH at WOT, but better safe than sorry). The other drawback is the V4 looper charging system is pathetic to say the least. My 140 only put out .6 amps at a 700 idle, 3.6 amps at 3600, and topped out at 8.3 amps at 6000. So it doesn't take long for an electric pump to pull your battery down at slow speeds.
Let me check....
Let me check the parts bin. I just stripped down a 140 looper but I am not sure I pulled the vro pump or not.
Kamikaze
If you are interested I can sell you one of my spares, I have two, this one is off because I am running an electronic fuel system. it was purchased less than three years ago, as shown in pictures I have taped over the inlets to prevent dust.
I am asking 110 including shipping.
