470 Overheat
dan4836
I tried just about everything...
My boat runs great except a very slow heat up after 3200 RPMs until boil over.
I replaced:
1) Thermostat
2) Water pump and housing (twice to be sure)
3) Removed the 3" heat exchanger and replaced with 4"
4) Flushed out the seawater circuit
5) Removed the riser and flushed and cleaned
I installed a new 160 degree thermostat. For some reason, my temp will stay at 120 at rest and increase past 200 very slowly at 3200 rpms
Can the thermostat be installed up side down? I have the springs facing down. One forum I read states the sealoc manual shows this install incorrect.
My only other option is head gasket?
Any thoughts?
do a compression test and look closely at the plugs, find the one that looks brand new. make sure you don't have old impeller pieces stuck in the power steering cooler
Impeller parts
I don't have power steering and I removed the voltage regulator as I have the upgrade alternator kit. My seawater circuit is very streamline and I back-flushed the circuit.
It has to be a head gasket or riser? My mechanic told me you sometimes can't tell if the riser is bad just by running water through it.
I've had a brand new thermostat not open up fully causing an engine to run slightly hotter. Replaced it and everything was good to go.
what brand of water pump did you use, I've been burned before using aftermarket pumps. you can plumb in a garden hose y valve between the heat exchanger and the riser, run another hose off the y valve to dump overboard, while running, crack the valve leading to the over board discharge, if the temp starts going down, you have a restricted riser. Be careful, don't starve the exhaust of water or you'll burn the hose
Pump
I used Mercruiser parts.
On the muffs, I can't get the temp gauge over 120.
In the water, temp gauge will stay at 120 at idle.
At 2800 RPMs, I can run all day around 170 degrees.
As soon as I bump the throttle to 3200, the temp will slowly rise to 200.
If I open it up, it will quickly jump past 200 and boil.
My recovery tank makes all kinds of noise...I am not sure if it's air or boiling coolant?
If it's air, then I know it's the head gasket.
My research tells me you can't find a small leak with a compression test because it's not enough pressure at low RPM's to find. Also, a leak down test may not work either.
I don't want to pull the head and find it's something else.
I do notice the riser gets hot as well as the heat exchanger. This still points to seawater not flowing fast enough?
Thermostat Issue
Does anybody know which way the thermostat drops in?
I have the older 470 with iron manifolds. I installed the thermostat with the springs down.
If the thermostat is upside down, I am assuming it will cause a high speed overheat.
Thanks for your help...
The spring should be facing the heated water.
A simple test to see if your t-stat is working properly: Take your stat and put it into a saucepan full of water. Bring the water to a boil. Remove the stat with a pair of tongs and look at it. Make sure it's fully open. Then, put a piece of string into the opening that occurred when the spring retracted due to the heat. Let the stat cool and capture the string. Then place the stat, suspended by the string, back into new, cool water and bring it to a boil again. Using a candy thermometer, measure the temp of the water as it's heating up. When the spring opens and the stat drops off the string look at the thermometer reading. That will tell you exactly what temp your stat is opening at. Check it against the reading stamped on the stat housing to see if it's within specs.
Spring facing the heated water
Then that tells me my thermostat is installed upside down.
The heated water is on top from the engine - the spring should face up in that case.
Another thread showed the exact same thing. When the person fliped the t stat, everything ran great.
my advice would be remove thermostat and try it see if it over heats
A easy way to check for a head gasket leak or cracked head
(1) you need 4 long screwdrivers
(2) connect hose to engine and run it till its hot
(3) remove all 4 spark plugs
(4) place a screw driver down each spark plug hole
(5) wait a minute remove a screw driver one at a time and check for moisture of the screw driver
(6) if you find one with moisture that's the cylinder that's leaking
I have been using this method since I have been in the trade it works
Pulled the head
I already pulled the head off and took it to a machine shop. He showed me the area he thinks the head gasket was leaking and he thinks it is causing the overheat.
I will be putting everything back together later this week and test rid is scheduled for Sunday...I will keep you posted.
is your exhaust riser closed up with rust scale ,ive been running a 470 for years ,never had a over heating problem, but changed the hole exhaust system a few years back
Riser
I am installing the machined head tomorrow...machine shop said it was warped. Also, installing new riser. Between these two items, overheat issue should be resolved.
I will let you guys know after test run on Sunday.
