76 cuddy bilge
Yes, it has that little portable toilet in the step through but no through hull fittings below waterline except for the transom, such as trim tabs (which are a HUGE help with passengers), depth finder, engine bolts, etc.
I haven't begun to track down the leak(s) yet. I'm paying a guy to convert my VRO to premix. I dropped it with him before I found this site or I would've done it myself. I'm thinking it's likely one of the through hulls on the transom as the rest of the hull is solid and without an signs of damage.
check the hoses that connect the scuppers to the through hull. Had a hard to find leak once, turned out a clamp had corroded & fell off!
No scuppers on this hull.
Gallagher, my '74 used to take on water between the cap and hull under the side windshields while under way, particularly in a chop or better...close inspection revealed large opening between which got immediate repair...Wellcraft didn't do a superior job cappin' these puppies for us...
:sleep:
Hey Reel, that's interesting. Did you need to pull the rub rail to get at it? I need to change that out anyways ...
Years ago, but I still kickin myself I took no pics...left motor on, removed rubrail and all screws connecting cap to hull (they may have been rivets I drilled out) and jacked the whole cap up except the stern, ran a 1 1/2" strip of 3/4" starboard around the inside of hull to catch new screws, then dropped the cap back down and w/3 drill motors (pilot, clearance hole and screwdriver) started workin' my way around till all buttoned up...rubrail back on, sealed remaining small gappage w/4200 and she was tight as could be after that...you run the strip so you can place the screw anywhere w/no tools on the inside...more details if ya want...
Sounds pretty slick. Wondering how you kept the cap up or even got it up. Also, how did you secure the star board? Hoping I don't need to go to that much trouble to replace the rub rail.
