Are trims tabs worth it?
Shucks
Well, on our first outing with the trim tabs installed and the livewell re-plumb, Jodi and I were heading to the Betsy Ross (25 Miles out) to pick up some cobia. After waiting weeks for the cobia run! Filled the livewell with 45 large menhaden and pushed the throttle down to head offshore.
About 3 miles off the beach, I started bogging. She would only turn 3700 rpms. Seems I got the dreaded ethanol issue. Shucks was not the word I used. When I came off plane and shut her down, I looked over the side only to see a 27 inch cobia checking us out. I put some baits in, but was more concerned with getting the engine to start again. Did that and we strolled in the shipping channel back to Tybee. Great news was the in deck wellcraft livewell kept 45 menhadden very much alive for 6 hours. And, the trim tabs worked great. As for the Betsy Ross cobia,..... shucks.
I have since then replaced all the fuel filters (even the hidden ones) and removed and inspected the VST. The filters on the Yami F150 are expensive. Then I pulled the Fuel injectors and they are being cleaned right now. Will pick them up in a bit, re-install and hope that fixes everything. it's a 3 week wait for mechanics right now. Fingers Crossed.
did you replace the filter on the bottom of the fuel pump in the VST? Thats the one giving problems lately. How you like that $90 fuel filter on the high pressure side. That thing used to be over $200 till all the dealers complained to Yamaha about them. For all you Yamaha fans(and all the DI 2 stroke fans), this is what teh fuel savings pay for
Cause the F225 is all new to me and I wanted no problems I had the whole engin serviced a few weeks ago. All new filters, oil change, lower unit oil and gaskets, new water pump, anoids, whole VST system including injectors, ran for any codes. For a cost of $1200!! OUCH! But I wanted to make sure a new to me motor was perfect as it could be the first time!! I will do most service now, but send tghe VST out every 2 years
$90 Filter
My guy sold me a regular filter to put in line on the high pressure side. I may try to back [pressure the filter and see what comes out. And even then, I think I'll do some surfing and try to find a 10 micron in line for that spot. Need to remove 55 gallons of gas from the tank just to be sure.
Sorry you had a problem...glad you made it back in OK and too bad about the Cobia gettin away, but they'll be there when you get the Yamaha goin again...55 gals gas...OUCH!!...gonna put it in the car/truck?...that's a helluva lotta lawnmower gas...
The gas is not that old. I may rethink it and treat the gas, then run it hard. Shame is on me cause the fuel water sep was 2 years old. I think that's what did me in for the most part.
I didn't replace the filter inside the VST because it looked like I could back wash it and I did. Will let ya'll know how it comes out in a couple hours......
I had to drain 110 gals of permix from my boat!! BS is using it in his 2 stroker and I have now refilled with all straight gas.
STARTRON fuel enzyme ethanol treatment is your friend here. I had 87 gallons of ethanol seperated crap in my tank when I bought it, treated it with the STARTRON and it burned through fine. Also I would look into the new YAMAHA spin on filters for your fuel water seperator in the boat. They now make a 2 micron filter that is twice as long due to all of the ethanol problems they have encountered.
Yes
All is well on the SS Whatknot. Ran great all the way to my secret fishin hole called "the titty bar".
Caught 5 stag bass and managed to catch one small enough to legally keep. Thanks for the 2 micron heads up Ferm!
So what's the story behind how the "Titty Bar" go it's name...I know there's one in there somewhere...and congrats on gettin the fuel probs settled...:clap:
Thanks for the tip on the Bennetts Spare. I have installed several pair w/o a problem so I know exactly what you are saying. It never gets that tight feel, the plastic just keeps on swelling. I've been putting it off because access to the inside is a PITA on the port side of this Whaler. I will take it off completely for the repair and report back. Also I need some of the little 90 degree radius makers that Bennett supplies in their kit. Annodized steel aint cutting it. :beer:
The fuel problem stinks. The Whaler has fuel from Thanksgiving. Stabilized but still, all my Opti has is the filter under the cowl.
you don't still have the fiberglass factory tank in your whaler do you, if you do, chunk it now and relpace it before it screws everything up, believe me, it will
Spareparts, I'm always curious and ready to learn. What is the problem with a fiberglass tank? I have an alum tank in mine so I don't have that problem, but I have no problems asking the teacher when I don't know something. Is it just the Whalers fiberglass tank or all fiberglass tanks in general? :head:
MOST fiberglass fuel tanks are made with resins that are NOT ethanol compatible and they will dissolve basically when ethanol enriched fuels are used as the ethanol will eat the resin and turn it into jelly. Then all your gas ends up in the bildge where it can eat the resin that makes up your hull.
worse than that. I worked on a 17 whaler last year that the tank had gone soft from ethanol. I checked compresion on the engine(4 stroke Mercaha), and found two cylinders at 0. I could hear the vlaves tapping, so I pulled the intake off and sprayed power tune on the intake valves till I could free them up. Everything had a red gluey substance on it. took forever to get the carbs cleaned(and the kits retailed for $150 each, took four). By the time I put a new tank in the boat, replaced the fuel lines, installed a water separating filter,replaced all the filters and primer bulb, got the compresion back up, rebuilt the carbs, set up the carbs(PIA), tuned the motor, changed teh oil and filter, water tested it, etc. The bill ended up being around $1600, and I didn't charge him no where near the actual amount of time I had in it. The ethanol disolved the resin from the tank, and once air hit it, it turned back into glue. This guy was lucky I was able to save the motor. As far as i know, it affects all fiberglass tanks(poyester/vynilester resin), not sure about epoxy resin, I emailed MAS epoxy about it, they didn't recomed epoxy for fuel tanks period, neither would West. Point of story, if you have a fiberglas tank, get rid of it. If you are using cheap plastic portable tanks, throw them away every four to five years and replace them with new one(don't ask how i learned that lesson), its cheaper to replace them than to repair the problems that arrise.
Fermanator and Spareparts.. THANK YOU BOTH for the lesson!! :clap:
These are the kind of things that you don't hear about until it smacks you in the face!.. I'll be certain to keep an eye out for them in the future.
All my present tanks are either Alum or SS, so I'm thinking i'm ok.. but I do have some spare 6.5 gal plastic tanks I use for long distance runs.. Might have to get new ones in a few years.. thanks for the info guys!!!
peelin,
"the Titty Bar" gets it's name from the fact that I have to cross the Ga state line to fish this spot.
All the good titty bars are just across the state line in South Carolina. Don't really need to travel to those any more. Sorry it wasn't more exciting than that..... I could make something up...
Shucks....
Up at 4:30 and prepped the whatknot for another try at cobia this morning. Idled out of the creek and,.... BAM! It was like my lower unit hit something. Mototr started idling really rough again, so back to the hill. Shucks.
I took her out last thursday and ran it hard and fast. Ran like a top.....
What the PH?
SPARE the tank in the Whaler is aluminum. I checked that out early on. 160 gallons worth in a 23 footer. The only time I have to worry about filling up is when I go somewhere and spend a week on the water.
SO I have a dilemma. Stale gas, constantly. (3 boats don't help) A solution to the water build up in the fuel is to keep your tank full. BUT my average outing I am only burning 30 gal. or less and I like the way the boat feels with about half a tank and the trailer likes it too. (500 LBS LIGHTER) Stabil is working thus far but the one filter is a concern.
