Boat Cover
cliffpaul2
Anyone have experience with a stock canvas (I guess), boat cover that fits well on a V-20 Cuddy? I'm looking for something to protect the boat from the sun in the summer and maybe from the rain in the winter when it's parked in the driveway. I'm not sure if a cover can do both, but I'm hoping to find something from Cabela's or something. Thanks in advance.
Cliff, Ive never had exactly what you describe, but at one time I kept a tarp over the entire boat, supported in the center by a single 2 x 4...bracket on one end to hook over windshield and sharp angle cut on other end to rest on motor (padded)...this worked really good once it was in place, but genuine PIA to cover/uncover...I cut down some trees and made an open area to store the boat...trees are the biggest problem, at least in my case... ;) :D...
Cliff i can help with that cover if interested.I'll get  Rod to give a quote, sunbrella is the way to go,If you are under trees you should use what they call a pencil pattern very fine black pin stripe comes in many colors helps hide sap dirt ect.
talk soon Jean
Just had this one made for $400 and it works great. I chose the heavier material (kind of like canvas) than sunbrella after I looked at a similar one that was 7 years old and was still in great shape. It is also very easy to put on and take off. Hope this helps.
Tracy
Now THAT'S a cockpit cover!...does it drain OK w/out a support leg under the center to "tent" it?... 8)...I guess Ophelia will tell for sure... ::)...
that should have a pole in a few months he's gona be upset with it.each time it rains its gona hold more and more. nice cover thats simler to ours.
I do have a pole, it is just not installed at this time. The cover is snug enough the rain just runs off. When winter comes I will have it installed.
Tracy
For what it's worth, I needed two poles on mine. I have one in the middle with a hole stitched in the cover for it and I bought a second one at Overtons to prevent the constant pooling I got near the stern on my bracket boat. Works great now (so long as the wind doesn't blow too hard). In the winter my cover sits snug in the cuddy while the shrinkwrap does the heavy lifting/supporting. No way my cover (which is identical to the one pictured) could support snow/ice even in mild CT winter without ripping.
Cliff,
I ordered mine from Cabela's online and it worked well last winter. Only setback was when my support pole broke. It handled the snow well. I believe it is breatable too. This was a Cabela's brand cover, item number IF-16487 and cost $179.00. A sundura cover costs 269.00 at Cabelas, item IF-010037. Hope this helps.
