spanishmak
can anyone tell me what i can use to clean up an aluminum trailer(you know that oxidation type stuff that builds up on it)I have tried pressure washing it but that didnt work.ANY IDEAS??
Well, a wirebrush and WD will work for sure, but that's a lot of elbow greese. Buy some Naval Jelly. The one for aluminum, not metal, spread it on with a paint brush, let it sit a while and then just hose it off. Viola...all done... (I like the chemical way because it gets into and cleans the pores of the aluminum.) Then either spray it with silicone or clear coat it with polyurethane.![]()
Didn't know they made NJ for aluminum...like the way that sounds...I was thinking of the polyurethane finish, too...will that hold up?
Reel, I have a friend that did his alum trailer that way about 6 years ago and the poly is still looking good. But there does seem to be a slight yellowing to it after all these years... (The poly, not the alum itself.)
NJ was originally made for the US Navy, and was made to remove rust from steel. Then several years after the original they came out with NJ for aluminum. One bottle is a pink label, the other is a blue label. I forget which is which.
I just pick the lint out of mine with my fingers but I can understand you old guys needing the jelly to make sure you get it all out.![]()
