Console rebuild Lowrance 12”
Leffe
About to rebuild the console so the 12” will fit.
But it will be a challenge making room for the gauges. RPM, tilt and tank. I can either make the hole console a bit wider or add something on top. What do you think?
Looks like a challenge. Not sure what engine you have, anyway to use NEMA to import gauge info and display on screen?
That was a very good idea but my suke is from 2013 and i think need som adaptors etc.
I cut it up and will make it 7cm wider and also move it 2cm to the left
Sounds like you know what you are doing - unlike me LOL. Definitely subscribed to this thread, can't wait to see your end product!
No i am totally beginner at this 😆 But if there is a will….
Did my first fibre glassing yesterday, just a sample with two layers of 300gr chop strand on a polyurethane board. Did the other side this morning. Hard as a rock now. I Will try tomorrow if it holds my weight ~90kg
It bugs me that the parts does not line up 1000% but we’ll se how it goes.
So from what I see,you cut the console in half and extend it by adding fiberglass and you never did that before? I will hire you to do custom work on my boat. I would never attempt that. Cutting the console in half? Not me. Great job I wan5 to see it when it’s done. What ar3 you going to paint it with?
