So this weekend I removed the rotten hard top that was on my boat when I bought it...and replaced it with a canvas. The old top was bolted to the tower so I now have open holes all around the top......What should I use to fill the holes....I was thinking silicone.
If you want to do it nice and clean, post some pictures , I thoughts are grind the holes open a little, then use Marine Bondo (gel) not kitty hair and fill, then sand and paint or gel coat it , it will be good as new.So this weekend I removed the rotten hard top that was on my boat when I bought it...and replaced it with a canvas. The old top was bolted to the tower so I now have open holes all around the top......What should I use to fill the holes....I was thinking silicone.
It would be a great place to run some red led lights!
filling with the screws is not a bad idea....but I think the silicone is the easiest route....appreciate all the help guys.....I've made a bunch of progress over the winter and will have to post some pictures soon.[/quote
Find a tap that will grab and put some threads in there. Aluminum galls easily on taps but lube it with WD40, kerosene or something like that and it will go in easily. Just don't use a tapping lube with trichlorethane, it will ruin the aluminum....or worse. Now use a short stainless round head machine screw and you'll have a slick rounded surface.
