Kicker motor questions (Suzuki DT 9.9)
Hi guys,
I recently purchased a real minty Suzuki DT 9.9 tiller control outboard. It has a 25" shaft and will I have issues mounting this to my V-20? I wanted to clamp it down to the tramsom and, get one of those connector rods that enables you to steer from the front by using the primary motor. I could also buy one of them auxilliary brackets if need be, but I wanted to ask you guys first. This motor runs so darn good and quiet, it should make an awesome trolling/auxilliary motor.
Also the mix is 100/1 but it says use Suzuki B1A oil or is it BIA? Can I just use the good old Wallyworld 2 stroke oil with the TWC3 rating? I also cannot find the age of it by the serial numbers. All the nomenclature plate says 725122 but then there is five numbers stamped in the case in front of the plate that reads 00993 ? Would this make it a 1993? Again it's a DT 9.9 hp I am slightly confused with this Jap made motor compared to my Johnny-Rudes. Any help will be greatly appreciated.
Hi guys,
