Need help on Helm w/ hydraulic
kman thanks, but for whatever reason I'm going with HK6400a....I don't know what the difference is b/t the one you have on eBay HK6324a and the HK6400a.
if the system has sealed boxes then that kit comes with 24' hoses also. that looks like a good deal if it has the hoses as the model number says. then you would only need the bezel kit.
I bought HK6400a from a reputable eBay seller this morning for $876, which includes 20' hoses and shipping charges.
I bought the 20 degree bezel kit for $75 at go2marine.com.
I'll keep you guys posted on this project once these get shipped. Thanks for all of your expertise!
:nice:
Good goin' BR!!...that's gonna be shaweet when ya get 'er done...worth every gray hair it puts on yer head and every dime ya shell out too...remember what all ya do, cause when I get the KAHUNAS to go hydraulic, I'll need lotta help w/it...:clap:
Thanks for the vote Reel! The install seems easy IMO. I'm going to use the existing cable to feed the hoses so that shouldn't be a problem at all.
I guess I'll be finding out how easy it really is very soon!
Good luck, Old Buddy...that upgrade will really enhance an already "Purdy Lil 21"...:love:
Wow, never heard of copper tubing in a hydro steering system. But if you can't tell by now, I don't know much about hydro steering :zip:
I know enough about steering cables though including how much they cost and how dangerous they can be when they fail! I got real lucky 2 years ago when running about 30 mph with 6 folks on board she snapped and sent the V into an instant sharp right turn. Luckily I throttled down just in time as we were heading straight for a wooden seawall on the lake.
No one was thrown out but it was scary.
An update on my hydro project...
In anticipation of my shipment arriving this week me and a buddy started getting things ready. First order of business was to free up the existing steering cable since it has to come out. I took the big nut off the tube and to my surprise the rod was not stuck in the engine tube :deer:
and not frozen at the helm :head:
So apparently the cable is stuck inside the whatchamadoodle, cable sheath or whatever you call it.
Oh well, no worries, all that crap is coming out! But I left it in so I could feed the hydro hoses :party: (Emphasis on CRAP!)
Next up, remove the wheel. I've removed about 4 or 5 stubborn wheels in the past with the 3/4 inch tapered shaft. They can be a pain in the tailbone! This one was no walk in the park. I thought I might be able to yank it off with help from my friend after spraying it down with some PB. No dice...she REEELY did not want to come off. Time to find that gear puller. Almost all of the wheels I've pulled in the past I've had to use a gear puller. Anyway, had a little bit of trouble with the puller slipping off and finally remembered to put the lock nut on the end of the shaft to hold the puller in place, but not before buggering up the threads a bit :zip:
Once the nut was on I tightened the gear puller and it was getting REEL tight, then BANG! It popped off :sly:and the gear puller crashed to the fiberglass floor :deer: and my buddy looked at me as if we had just ripped the entire console out :you:
Then I removed the helm and bezel mount. At this point I am ready for to install the new steering. This evening I'm going to work on draining the +/- 10 gallons of old fuel and charge up the batteries. Then she needs a good cleaning, new racor filter, and the owner may need a bottle of champagne considering July 26th 2008 was the last successful voyage for me. :cry:
Wish me luck.
I'm not familiar with the 2 ball pien hammer method....do share!
She was on there so tight I can't imagine anything but the puller would have gotten it off.
Actually, I'd say things are going smoothly so far, believe it or not. I will consider it a "rough" install if I run into something I can't fix in an hours time.
Perty work Blue. I was in up to my eyeballs myself tonight as I started rigging the P-line. Once I figured it out, the entire helm pod lifts off to reveal all the wiring, which in my case was a rats nest from a bunch a previously butchered jobs.:shut:I did get my plotter on before dark, so in all it was a good night.
CT - what a tease!!!!! You've got my mind going ape-sh!t. I just cant imagine how 2 ball pien hammers could be used to remove the helm, beside two people beating the wheel simultaneously from behind.
Slot, I hear ya...you sound like me. Worked on the boat after work the past 2 evenings right up until dark. It is rewarding though. :happy:
Yesterday evening I drained all the old gas out. I estimated there was 10 - 12 gallons in the v based on my last recollection of the gas gauge. I pumped 11.5 gallons! Dam gauge is spot on!
My 20 degree dash wedge came in, still waiting on the steering system. I have 2 mounting options, they are the pics on the left as seen below. I prefer the top one however my hole would have to be 5 1/2 inches to accomodate. As of now its somewhere in the 3.5 - 4 inch range. I'll just do the bottom one for now to get to fishing and if I'm unhappy I'll remount it with the 5.5in. hole:
Be sure to tune in tomorrow for more hydraulic fun!
:time:
jrou111, thank you for the interesting info...this is my favorite part of the article (at the bottom):
The steerting wheel is tightly seated on a tapered and keyed shaft. It may be necessary to use a gear puller to pop the wheel off the shaft. Typically just a slight amount of force will break the wheel loose.
:bsflag::bsflag::bsflag::bsflag::bsflag::bsflag:
Don't take the nut all the way off. Place a flat or ball peen hammer on the shaft with the handle under the rim of the wheel. While prying up with the hammer strike the first hammer with another hammer. Wheel should come right off. When replacing put a thin coat of grease on the shaft.
CT, is the the hammer trick you were referring to? I googled and found this.
:beer:
