billmongold
That sounds good. Didnt think of using 5200. Ive been thinking a lot lately about fabricating a central drain system like newer vikings have. Its basically 1 1.5 inch length of waste hose run along the port and stbd gunwale, slightly downhill, leading to a through hull aft. You plumb anything you want to drain into the hose. Vikings use it for a/c discharge, bulge pump discharge, shower box discharge, etc. It would work great on our boats for the same reason. Plumb the rod holders and anything else you want in there, install a through hull, and never worry about it again. Ive also been think about building a hybrid self bailing deck/showerbox system where id tee off the self bailing drain hose, install a ball valve, and run it to a showerbox (a sealed box things can drain into with a bilge pump and float switch to pump it out. This way you can drain things low and pump it out to a through hull placed up high). It like to consolidate things and be able to seal the bailers for when my boat is sitting low in the water.
