LAKEMI Iam confused are you saying that you are running 100to1 full throlled with no damaged to your outboard
That's the same stuff I got.I use Pennzoil but not the sythetic stuff. It is the one called XLF. About $20 /gal. I am running a 150hp Yamaha 2 stroke oil injection with around 500 - 600 hours.
Genie Aye, If I had a high tech motor like an Opti or an Etec I would run a better oil. But my motor is a 1990 225 carbed Yamaha. And I use a lot more that 5 gallons a year. If I puke a rod because of lack of lube I will go back to Yamalube.
I hate to tell ya Ferm but HPDI's require the same Yamalube that every other yamaha requires, 2M. It's nothing special, no magic going on there just 6 oil lines, one behind each reed block. There is also a little fed to the vst to lube the fuel pump and that's it
; I ran my 2003 Ski-Doo snowmobile, 700cc mototor, about 135HP, clean out of oil and was running about 80MPH across a hayfield in northern MI, turning about 7800rpm on the tach. (The out of oil part is a much longer however embarrassing story). The motor seized at 80MPH as I was thrown into the handlebars and came to a dead stop; the motor locked up tight. I had Amsoil Interceptor 2-stroke oil in the motor. After about 10 mins the motor came lose and I drug the sled home, tail between my legs. At home tearing down the motor, I all had to replace was the mag side piston rings and hone that cylinder. NO scuff on the cylinder wall or piston, and the PTO cylinder was just fine. Amsoil as a lubricant is just that good, and is arguably the best synthetic on the market, not to mention they have been doing it the longest. They also have a tremendous engineering department that welcomes challenges to the quality of their product in addition to claims of failures and burn downs.
Out on the Great lakes we run 3/4 throttle. around 30mph.
