Water in lower unit?
No good, I replaced the oil drain plugs,water impeller ,two thermostats and the base for the water pump housing , I ran my engine two times on the ear muffs never put the prop in water,changed the oil and its worst , the first two times I changed it it was a dark green now after everything I did it's a light green and the oil I'm using is pennzoil 80 -90 weight .what did I do wrong ?
put some of the green lower unit oil and some water in your wifes blender. Then report back to us what happened.
Or maybe try some in a can and use a spade bit in a drill to mix it up to see what color it will be. But any oil mixed with water I saw looked like a milk shake.
I got quick silver lower unit oil I think it's blue coloered I'm going to put it in tomorrow run the engine and drain it to see what color it comes out, I will let you know what color tomorrow thanks for the replays
