water pump/lower unit
So far what I'm seeing there may not be a complete kit available, however the parts are except for the housing.
Sierra makes the parts for most waterpumps like Bendix makes most of the brakes for automobiles.
I'm trying to find the correct part(s) number(s) for your pump.
and the housing isn't really something that can "go wrong" right? I mean unless it rotts out. From the looks of most of the engine I am not to worried about that.
RICKS OUTBOARD MAR
105 POPES ISLAND
NEW BEDFORD, MA  02740
 SPICERS MARINA
93 MARSH RD
NOANK, CT  06340
CAPE MARINE
140 MACARTHUR BLVD
BOURNE, MA  02532
 OAK LEAF MARINA, INC
218 FERRY ROAD
OLD SAYBROOK, CT  06475
OCEAN PERFORMANCE
280 BOSTON POST ROAD
Thanks for trying!
I got the Customer service # for mercury (though I left it @ home ::) )
I am going to try and give them a call. Like I said today I am going to remove t he lower unit and hope that everything looks brand new ;D. I just bought the boat last August and had it serviced before I picked it up, so maybe they replaced everything? ??? ;D
Well I talk to a guy a Sierra today, 2 minutes later I had the part # I neede, 18-3217.
Of course No one around here has it so I oredered it, and why I wait for delivery I am going to still change out the impeller in the lower unit to eas my mind for this weekend fishing..
Look at the tube adaptor to make sure it's not deformed from improper installation . The 75hp we just put a complete pump in had a damaged adaptor (this is a small pvc looking thing that is about the size of a 1/2" pvc coupling that goes from the water pump to the tube to the powerhead).
Well everything in the water pump looks brand new, but I replaced the impeller any ways.
Before I pulled the unit off I put it in reverse,neutral,and frwd to see how the prop spins so I have a reffrence later. In gear in would rotate in the correct direction with alitle preasure.
SO I put the engine in neutrral (thats what the book siad) and pulled it off. Everything went smoothly until I went to put it bavk on, it would go all the way up and stop about 1/2 inch from the top. After 1/2 hr of playing with everything it went up.
Put it in gear nothing prop spun freely ::)
Took it off, played with everything again about 10 min later put it on and it seemed to work.
when in neutral, the prop spins freely. But when in gear it is alott firmer then before in the correct rotation and is the same in the wrong rotaion.
I am going to go hook the hose up to her now and see what happens when I put it in gear.
Went in/out of frwd/rev alright so I think I should be allset.
The only thing that was wierd was, I did not put the electrolis plate back on yet and when I turned off the water it alott of water poored out of that hole. should the lower unit be filling with water?
It also started spitting water right away, no warm up time that is normal with merc/mariner.
In all honesty, you'll not be able to determine if you've gotten the dog out of time until you put it in the water and run it. Sounds like you done a reasonable job. I'll say good job if you don't have to adjust it out on the control cables or redo the dog sequense. Oh and if it pumps water the way you want, that adds points. ;D
