If you're having problems with your trailer lights, get a set of LED submersible lights. I also run a third dedicated ground wire from each light up to the connector. I find using the trailer frame as the ground is not always reliable.
Agreed on the LED's. Brighter, safer, easier to be seen and more reliable. Less likely to have the police pull you over for lights being out. Harbor Freight sells them for under $40 for a complete kit...
Permatex dielectric grease - good stuff - https://www.amazon.com/gp/product/B000AL8VD2/Second, use special electrical grease on the wires before joining them together.
it was sooooo nice. Had some time so I worked on the boat. Got a lot done, replaced the thermostats, disabled the VRO (after making sure the mixed gas was being burned), finished painting the rod boxs, got the reg numbers on. Over all a good day!If you only have to mess with them every few years, your ahead of the game. I have 5 trailers, 3 boat & 2 utility, i tried about 4 sets of the led and went back to bulbs. I trailer a lot and I think the vibration takes its toll on the led lights. I run 3 wires from each light to the pigtail. And when i put a new bulb in, i use the dielectric grease on it.
I know how to work on a bulb set up, led's, you just throw away and go buy more.
Well took some time yesterday and today to work on the boat. Replaced the water pump, the gear oil, and drained the carbs. I lost my engine flush muffs so I just took the boat down to the lake and dipped the engine. Took a bit but get it started when I noticed there was no water coming out of the telltale.. I had other plans so I didn't have time to figure it out. Today pulled the lower unit off again and noticed the pipe in the mid section slipped out of the pump. Realigned everything put it back together and it works just fine. That shift rod screw is the biggest pain in the a$& I hate that damn thing. I never seem to get it right.
I working on the boats title/reg and I should be ready for some water trials.
My wife named the boat today as well. Our son Finn is 2 and crazy wild all over the place all the time. We were kicking around some names, and talking about seeing him with a live fish on the line for the first time next summer when she stopped mid sentence and said "WILD FINN". It fits perfectly!!
